  1. Okay I have got past the virtual dub section, done tmpgenc, done vcdeasy, trying to use CDRWin Version 4.0A but it says no cd rom recording device found on the SCSI or IDE bus! What shall I do?
    May 2002
    lorain
    TIs your burner new? i had the same problem it might not recongnize it. I'd sya get Easy CD Creator Platinum or Nerio 5.5.8.0 Mine dodn't work with anything except nero at nero.com Also I have Ulead DVD Factory works. Got to pages look for support. If yuo know the maker ofyour burner ask them in an email )which their address can be found t their page). Tell them what programs support your burner, make sure you include the brand and speed/model no. Other than that just be patient and wait until a new program comes out. But, then agaon this may not even be your prblem but its very common
    hope i can help in any way
