  1. Hi to Everyone
    Wonder if anyone could help me please
    I am new to Nero and I am having problems. When I burn avi movies in vcd format, they play ok for a while then the sound goes out of sync with the video.
    I have a cyber drive cd burner and use Nero 5.5 burning software
    What can I do to correct this problem
    any help would be great
    Maggi
    Las Vegas
    Are you using Nero to convert the AVI's to mpg? Nero does not do a good job converting, in fact, it sucks. Suggest you download Tmpgenc & use it to convert your AVI file to mpg first, then burn it with Nero. read the Guides posted on this site, they give more detailed infos.
  3. Hi to everyone
    Thank you siadodo for replying to my last query
    I went to the tmpgenc vcd site and downloaded it,
    I have printed off all the relevant info
    Can you hep me with one more thing
    When tempenc has finished encoding what do i do next, to be able to burn it onto cd using nero
    I know I am really green about all this
    If anyone can help it would be great
    Thanks Maggi
    Las Vegas
    After converting your avi file to mpg, it is ready to be burned to a CDR. Remember in order to make a VCD, your file must be mpg-1. To make a SVCD, your file must be mpg-2.
    You can use Nero or VCDEasy to burn, I find them to be the easiest.
    When you converted your file to mpg with Tmpgenc, if you had used the VCD template that comes with the program, you should have a VCD compliant mpg file. If you didn't, Nero will probably tell you that your file is non-compliant, simply turned off the compliancy check, and continue to burn the VCD.
    Suggest you read Sefy's guide for newbies, it is quite good & helpful.
  5. Hi Siaododo
    Thanks for all your help, Vcd burned succesfully,
    The first of many I hope
    Regards
    Maggi
  6. Oh Maggi,
    Also try and keep your MPG files that you convert to VCD as close to the
    VCD standard as possible.. This is important if :D :D you plan on sharing you homemade VCD with Family and friends..Some of your family members
    may have DVD players that won't play Non-Compliant VCD....
