Hope i'm in the right section, because i've only just registered.
I know how to convert divx to vcd using Virtual Dub and TMPEGEnc.
The problem is on some of my divx i need to use another codec for the sound to work. I think the filter is AC3 or something like that.
So when i try to extract the audio to a .wav in virtual dub, it will not let me, giving me a message about the sample rates and compression.
Can anyone help me?
Much appreciated.
Barry Lee.
Panasonic DMR-ES45VS, keep those discs a burnin'
cheers mate, that's done the trick.
Seems worth using this forum, you get a great response.
Thanks again.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
