Hi, Can any1 please tell me how to burn a .mov movie as a vcd?
Before you burn the VCD you have to convert the .mov to .mpg.
http://www.vcdhelp.com/convert.htm
I suggest to use TMPGEnc, because it is one of the best MPEG encoders and free (well, MPEG-2 usage is limited). Make sure you copy the qtreader plugin to the TMPG dir. -
i have unzipped tmpenc to a folder on my desktop, i then went into quicktime and right clicked the plugin and copied it into the tmpen folder but i only get the sound enter into its box when i drag and drop it, any more help?
Software to put png slides and movies on same disc?
By rodney in forum Newbie / General discussionsReplies: 12Last Post: 27th Aug 2011, 22:52 -
How to put 15hours+ SD video into one 25GB Bluray disc
By kmnorya in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Sep 2010, 05:04 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 16:49 -
Put severeal AVCHD Mini-Disc onto a DVD-5: How?
By gekko_video in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Apr 2008, 15:35 -
What's a good format to use to put several videos on one disc?
By DVDNewb in forum Video ConversionReplies: 2Last Post: 21st Jul 2007, 12:28
