I have a mpeg that is set to be burnt as a vcd, I load it thru Nero and while the file is meant to run for 1hour 11 minutes, when it is done going thru Nero it only is recognised as giving me 11 minutes actual mpeg.
How am I missing the extra.
I can watch the mpeg with WMP no problem and I get the full thing, but not after it goes thru Nero..
help please.
I was wondering what the source of this MPEG was? DVD? DIXV? The reason I ask is cause I has the same problem when attempting to copy 'The Others'. I used smartripper to create a single M2V of the movie (that I was able to view in WMP) and followed the same authoring process that has worked on the last 12 movies. When I copied it to DVD the movie was less the one hour long. As it turns out when I created the M2V I did not strip the 'angles' sceens. Once I stripped the out & redid the movie everything worked as normal.
I don't know if this will solve you problem but it is something to consider.
D -
It was originally froma digi camera as it is a bootleg from a concert. I didnt take the film I just d/l it.
Now I want to make it into the vcd file that it is meant to be,
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 15:13 -
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 17:32 -
20 minutes to burn a DVD!
By persephone in forum DVD & Blu-ray WritersReplies: 22Last Post: 9th Dec 2010, 15:12 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 03:19 -
latest few minutes missing on DVD
By coxy in forum Newbie / General discussionsReplies: 8Last Post: 5th Jul 2007, 03:47
