Hi,
This film is 101 mins long and should easily backup to 1 DVD-R.
However, the movie VOBs total c. 7GB. I stripped out unwanted audio and subtitle streams in IfoEdit 91, and I'm still at about 6GB for the movie.
I thought that if the film was under 2 hours there is a good chance of it fitting.
So why is it still so big?![]()
The audio stream is AC3 5.1.
Is it the video bitrate that is really high which is causing the problem.
I know I can put it onto 2 DVD-Rs but I would like to keep on one disc if poss, and that I can re-encode but I don't want to lose quality
BTW, I am a newbie so I may be talking crap.
Oh, I did the extras OK cos it was under 4.5 GB.
Can anyone tell me why?
Cheers,
BTW, this forum and the guides have been helping me a lot this past week since I got my writer![]()
Sorry dude but it looks like re-encoding is your only option if you want to keep the movie on one DVD-R. The length of the movie does not have much bearing in regards to the VOB file size. I have several 90min +/- movies that needed to be re-encoded because they were larger that 4.7(4.33) GB. It all depends on what bitrate is used to encode the movie. As for re-encoding, you would be surprised how good a re-encoded movie can look. I just ripped a movie using TMPGeng with all quality options turned on and set to the max. (Painfully slow. 16+ hours) On a 35 inch TV I was unable to tell the difference between it and the original.
Thx for your reply m8.
I think I feel a TMPGeng training session coming on......
BTW, is this the best tool for re-encoding cos I've seen ReMPEG mentioned alot.
Cheers. -
Alot of people here swear by ReMPEG cause its easy to use & produces good results. My only gripe is that I am unable to produce good quality movies if I use a DVD MPEG2 (i.e. 29fps) source. It introduces bad motion artifacts into my movies. I tried all the options that I could find but it will not limit the FPS to 24.
TMPGeng is able to process all my movies without much drama but its got a steep learning curve. It also has A LOT
of options.
Between the two I would recommend TMPGeng. But try them both, after all, you should be the one to decide what is best for you.
D -
Woohoo,
Managed to re-encode The Usual Suspects from avg bitrate of 9Mb/sec to 5Mb/sec and it fits on one DVD-R (inc. the flash menus!).
You were right, the difference in quality is minimal.
I used ReMPEG cos it was quick and easy, but will try TMPGeng next time after I have learnt how to use it.
Thx for your help.
C.
PC won't start after it froze during the usual work - SOLVED
By Jeremiah58 in forum ComputerReplies: 10Last Post: 9th Oct 2010, 09:04 -
RipBot CQ20 lower bitrate than usual
By vertigoanduminas in forum Blu-ray RippingReplies: 7Last Post: 10th Feb 2010, 06:35 -
YUYV/YUY2 signed/unsigned, RBG and "usual" values questions
By Guimauve2 in forum ProgrammingReplies: 0Last Post: 8th May 2008, 18:15 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42
