Results 1 to 18 of 18
    May 2002
    Romania
    I have a VCD 2.0 player NAPA 311 and I want to burn my own Photo CD album or slide shows.I have photo in JPG format.
    I tried to burn Photo CD with Roxio Easy CD power edition 5.0 but it does not work.
    Please help me to make Photo CD or slide show that can e played on my NAPA 311 VCD player.
  2. You can make a slide show just using nero (up to 99 pics)
    Else look in the guide section here, Using the guide u can make a
    slideshow with up to 1900 pics using all free software.
    good luck
    May 2002
    Romania
    I tried with nero but it dosn't work to a stand alone VCD player (NAPA 311 is my player)
  4. I own a Napa 310, and followed the User Guide at http://forum.vcdhelp.com/userguides/92056.php. That plays fine, on my Napa, but my Yelo 800 DVD won't touch it. For my Yelo to work, i had to use VCD2TK, with the subsequent brain damage this program inflicts. I suspect VCDEasy's photo vcd's aren't exactly spec.
    Nothing if not difficult
  5. Try SSMM at
    http://www.joern-thiemann.de/tools/ssmm/
    Works great and it's freeware.
    vcdddude
  6. If you absolutly cannot get it to work you would always inport the pictures into premere (or something like it, studio dv etc....) and render an Mpeg movie out of it and burn that to a vcd.
    just a thought if your having that much trouble with it.
  7. I have used EZ CD Creator 5 PLatinum (It lets you add music to the slide show), I have also used Nero. I have Ulead DVD Picture Show, it works well but has file number limitations (99 per slide show, up to 99 slide shows on a CD.) You cant do transitions with this. If your slide show will play on thePC but not the TV, try using CDRW.
  8. Ulead DVD Picture Show ( VCD/SVCD/DVD)
    Apr 2002
    I have Ulead's DVD Picture Show also. I like it alot (add music and all). How well do these other programs work, in comparison? Do they all have a "add sound" capability?
    Nero: 99 slides
    Ulead DVD PS: (99 per slide show, up to 99 slide shows on a CD.)
    What are the other programs max pictures (e.g SSMM)?
  10. I don't think there is a max on the others except for cd capacity. Also, I saw a reference in this forum that you can get around the 99 max by using Nero to burn after you have created the ss. I haven't tried that. I haven't gone beyond putting 3 different ss on one cd and then watching it on my tv. I can do that and use the remote to navigate.
  11. I also forgot to mention, that Nero wont let you build and add sound. I have also done ss with PowerPoint but it is not as friendly. I think the most user friendly is Easy CD Creator Platinum (I don't think the other versions of CD Creator won't let you add music). There are more transition options with the DVD Motion picture SS.
  12. I also forgot to mention, that Nero wont let you build and add sound. I have also done ss with PowerPoint but it is not as friendly. I think the most user friendly is Easy CD Creator Platinum (I don't think the other versions of CD Creator won't let you add music). There are more transition options with the DVD Motion picture SS.
  13. rickblackmon:
    Rick: Is there a fade-in, fade-out transition option in DVD Motion Picture. Where can I find the DVD Motion Picture software?
    Appreciate your response!
    Mar 2001
    Holland
    Does Ulead's DVD pictureshow really do SVCD's, I've
    only seen a reference to VCD 2.0 in the 'HowTo userguide' ?
  15. Ulead DVDPS can't make SVCD(VCD 2.0 or DVD)
  16. Ulead DVDPS can't make SVCD(only VCD 2.0 or DVD)
    Apr 2002
    It doesn't matter, the stills are superior to SVCD video (480x480). Still pictures in VCD are as good as SVCD stills.
    http://www.vcdhelp.com/vcd.htm
    Extra:
    Menus and chapters
    Still pictures in 704x576,352x288
    http://www.vcdhelp.com/svcd.htm
    Extra :
    Menus and chapters.
    Still pictures 704x480,352x240
    Slideshows are great!
  18. Member
    Apr 2002
    Like I said the VCD pictures are as good as SVCD:
    Here's the NTSC values for VCD (I had PAL values for VCD in my post above)
    Extra:
    Menus and chapters
    Still pictures in 704x480,352x240
