Hi Everyone,
I just purchased a Pinnacle Systems PCTV Pro card which I intend to use to caputure some old cartoon's from my VCR to VCD.
Having only just opened the box,I have just discovered that it has come with Pinnacle PCTV/Pro V5.00 drivers on its installation CD.
I'm a relative newbie to all of this,but according to VCD & Pinnacle's forums I cannot capure with Programs like VirtualDub & TMPEncg as the version 5 drivers are WDM,& not VFW.
I also have Ulead's VideoStudio 4SE separately,which I was also considering for AVI capturing,but again I'm worried that the WDMV 5.x drivers make this program also incompatible.
Everyone here seems to suggest that the PCTV Pro V4.02a/4.x drivers are more stable & VFW compatible.
Can someone please tell me if there is a link somewhere that I can download the older V4.x VFW drivers?
The only drivers I saw on Pinnacle site's was for the PCTV card,(Not the PRo version),for 4.02a were listed as being XP drivers.
I have Windows 98 First Edition,so I didn't think these would be compatible either.
If there's a site that has the original VFW Version 4.x drivers,then please someone help me?
Alternatively,is there any way Virtual Dub,& TPMGEnc will work with the newer version 5 WDM drivers?
I am a newbie so I'd really appreciate your help please.
Thank you.![]()
I think you shuld test teh PCTV drivers. Just download those and try them out. PCTV, PCTV Pro, PCTV Rave uses the same drivers I think.
/wertigo -
I forgot to add the link to the set of older drivers I did find...
http://www.pinnaclesys.com/docsupport1.asp?division_id=1&langue_id=2&product_id=6&prod...CTV&page_id=62
Does anyone know if these V4.02a drivers will A)Work with the PCTVPro & B)Be compatible with Win98 First Edition?
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 20:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 18:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 23:40
