Newbie here . . . I am trying to play a VCD on my PC (OS W2K) and I keep getting the following error message:
"#ES32274 [SIMMCIDGVWindow] The MCI device you are using does not support the specified command." The VCD has it's own player on it, Sony VIDEOPRESS Player, is this the problem??
thanks
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=52286&forum=5&0
let this dude do the talking
try the link
F1!! F1!! F1!!! -
thanks . . . actually I had found that link previously and tried that, however I will admit I am very computer illiterate. I checked my system directory and I did not have that file, so I copied it from another PC, and placed it in my system folder . . . should that have worked???
try the link
[/quote] -
well i think the link i gave you. showed you where you should put the file in the exact folder.
And yea that should work if you get the file from another computer. but it better be in the Correct spot exactly.
hope that helps
F1!! F1!! F1!!!
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 25th Aug 2011, 00:26 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 15:29 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 16:20 -
'Some' disks won't play...
By Anonymous4374945 in forum Newbie / General discussionsReplies: 7Last Post: 30th May 2007, 17:14
