If anyone has any ideas: I have a movie that was split into two cd's and posted as VCD. I can view the movie on the computer using quicktime but cant burn it to watch it on my standalone. Toast says it is unrecognizable or not a toast image and to use a demuxer (or some message like that)
any help with what i can do to be able to burn it would be great.
baka
If you have Quicktime Pro try to export as Toast ready Video CD. See if it will export it, if so you can then burn that file.
Oh. But if Quicktime refuses to export to Video CD, then export to Quicktime(.mov) and export the .mov as Video cd.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
