I'm using the Dazzle DVC II to capture from VHS. I tried to capture a sitcom from a VHS tape that has some fade in/outs to the next scene. I used the SVCD 480x480 template. For some reason my Dazzle stops recording right after a fade out 30 mintues into the capture without me pressing the stop recording button. Is there a way to correct this?
Zoinks2, how much hard drive space do you have? The DVC II will stop on its own if there isn't enough space available. Probably not the case but a start anyway...
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Pinnacle Dazzle 'DVC 170' Woahs...
By synthecypher in forum Capturing and VCRReplies: 4Last Post: 3rd Jun 2010, 22:02 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2007, 07:58
