I don't know where to start. I have never had problems burning CDs before but now I can't seem to burn some movies that I have downloaded off the net. They are all .bin and .cue files. I have tried to burn these files more than 20 times already and each time I get an error message at the end, and the CD has not been burned at all. It also takes a long period to finish the finalizing stage, almost 10 minutes anymore. I have tried just extracting the the MPEG files themselves and burning them manualy using Nero's Super Video CD feature, but believe it or not I still got the same problem. I have tried to burn these CDs many times, and not once has anything been burned to them. Actually when I try to burn a CD, my drive is really quite. I don't hear the CD Spinning in the drive, the light blinks but the drive is quite. Then when the CD is done nothing has been burned, it's not even corrupted. Hell I'd take a corrupted CD anyday rather than a CD not being burned at all.
I'm including a linke that has a copy of my error log when attempting to burn the files using Nero. If you can help, please read this file.
Nero Log: http://mikel.4mg.com/pub/NeroBurnLog.html
Thanks, Mike.
What version of Nero? If it is 5.5.8.2 (latest) check the misc tab - if "Cache files from disk & network" is checked uncheck it
Panasonic DMR-ES45VS, keep those discs a burnin' -
Thanks for the info, but that didn't remedy the situation. I am able to burn other files using Nero ok, (IE same type of files) but these just won't do it for some reason. These are the error messages (which can also be found in the Log file) I get when it tries to finalize:
- all writers idle, stopping conversion
- Illegal mode for this track
- Could not perform end of Disc At Once
- Invalid writestate
- Burn process failed at 1x (150 KB/s)
- SCSI not using temporary buffers 20 out of 20 temporary buffers allocated
I also tried recording the Disk in TAO (Track-At-Once), but it says the medium is not supported and ejects the disk. I was afraid that my CD-RW drive might have been damaged, but I can tell it's not since I have recorded others since then. I also tried burning using CDRWin but the same problem came up, [No Burning to the CD took Place].
I appreciate any futher input.
Thanks for all help in advance.
Mike. -
P.S. Yes, I am using the current version of Nero 5.5.8.2
I am still needing help, if anyone can please read this and help me I would really be thankfull. I can't seem to burn certain CD-image files to my CD's. Each time I try I get an error message, then when I go to check my CD, nothing has been burned to the CD at all.
Please read this error log for details on the error:
http://www.mikel.4mg.com/pub/NeroBurnLog.html
Please Help, I am very desperate...
Thank You.
Burned in subtitles help
By aftermay in forum Newbie / General discussionsReplies: 18Last Post: 30th Mar 2013, 13:24 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
