I've been tinkering around with VCD, SVCD and MiniDVDs. I'm a little disappointed with either the quality or the time duration that can fit on a CD-R/W. Just recently I got an MPEG1 352x288 25fps 1152kbit/sec file, from a consumer VCD (one you would buy for a title film), and the quality was too good. How was it done, I've used TMPGEnc, LIGOS and ATI AIW and never come close to this. I would think it may have been professionally rendered with a hardware encoder? Can anyone tell me what I can do to obtain this quality and compression?
I use a VideoOne real-time mpeg1 encoder, using an Optibase should give even better quality still. But you should definitely be able to get a similar quality using a software encoder if you are encoding from a really good source... What is your source in this case?
Al wants to know the same thing. TMPGEnc is nice, but not nice enough.
I've seen some amazing VCDs. Even a DVD rip to VCD doesn't even come close. Generally speaking, the VCD picture created with TMPEnc does look good. A prof. VCD does look better.
Al wants to play with the prof. thingy they used. Gimme one.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 17:21 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
