Hello to all. I will try and be as specific as i can with this problem: I downloaded 3 .bin files and 3 .cue files (1 for every disc). I then use CDRWin 3.8G to burn to CD-R. So far so good; When i load the .cue sheet, i get an "error: invalid CUE SHEET command at line 5
Previous file is not a multiple of the specified block size" message! I then opened the CUE sheet with notepad and compared the disc 1 cue sheet with disc 3 cue; they are identicial! Here is the disc 3 Cue sheet:
FILE "DF.CD3.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:10:00
Disc 2 Cue sheet:
FILE "DF.CD2.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:10:00
Disc 1 Cue sheet:
FILE "DF.CD1.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:10:00
Disc 3 is the disc that i get this message on. Can anyone offer any help with this? thanks for your time!
Chris
What i would do since i know the three will not be identical, use Nero just hit burn image and use the MODE2/2352 it will figure out the rest for you. hope this helps.
Thanks for your reply but i use to use Nero and my Apex AD-600A will not play (S)VCD's when burnt with Nero. I mostly use VCDEasy and CDRWin when buring .bin files.
Chris -
Maybe the extra period in the filename is not good - try renaming df-cd3.bin and df-cd3.cue (edit cue to use new filename)
Panasonic DMR-ES45VS, keep those discs a burnin' -
You could try that but I wouldn't think that it would matter...
It could be that your BIN file is corrupted... (not good).
A way of regenerating a working CUE file (e.g., if you have no CUE file at all, just a BIN of a VCD) is to use VCDXRIP (one of the proggies in VCDImager) and then immediately use VCDXBUILD on the generated XML file.
You can use VCDEasy as a GUI to both tools if you don't like using command console tools...
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
