I've gone through all the user guides and followed Sefy's to the T.
I used CloanAD's proggie to rip the DVD to an MPEG and it works fine. I used Nero 5.5 to create the VCD.
The problem is the disks will not play in any of my DVD players (I have 3) and all of my players do play VCD's.
I followed Sefy's instructions exactly, and I'm wondering if possibly I need to change some settings?
If anyone could lend a hand, I'd really appreciate it. Thank you!
VCD or SVCD is any of your players compatable? and do they read CDR's? some players are picky on the type of media you use i have had problems with some brands also.
I have played VCD's and SVCD's in all of my DVD players at some point with no problems.
I'm wondering if it's possibly the goofy directory tree that Nero is creating? It seems kind of complex for a VCD.
Thanks. -
jeffrey, the Directory structure Nero creates is standard, but you never mentioned if you played CDR media, are the VCD/SVCD originals ? those you played i mean.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Dvd to Vcd
By tryst1 in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 02:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
