Ive been ripping dvds for a while now and recently i just noticed that i can no longer rip any higher than 1.3x on a 16x dvd-rom using smart ripper.
Has anybody else had this problem???
Not had a chance to check the dvd out yet but it seems to be working normally.
Does anybody have any solutions???
Cheers.
Doh Doh Doh!!!
Have you done any changes lately ? checked latest IDE driver / ASPI layer ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Ive made no changes at all to my system.
The problem is with the drive itself.
I hope.Doh Doh Doh!!! -
Although it is possible for a drive to go bad, most problems are usually in the software department, I strongly suggest you check what I asked you earlier, and then report back.
Best Regards,
Sefy Levy,
Have you defragged your drive lately? Do you have any apps or screensaver running in the background? You might want to check these out and see if your speed improves.
Problem installing Real Alternative Lite.
By csh in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2010, 13:24 -
Lite-On LVW-5115GHC+ timer programs problem
By smik in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Oct 2008, 22:39 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 14:02 -
any new drives better than Lite-On for ripping?
By spiffy in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Aug 2007, 03:54 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:32
