ok i downloaded Shallow Hal..
Used Vdub to extract the audio (AC3) and Headache to convert to Wav audio.
Then TMPGENC (toolame) to convert the avi to mpeg-1 (Vcd), when i pop it into my daewoo 5800 at first it played fine...as the movie goes every now and then the audio goes out of sync.. and the video hangs.
I did change the settings from cbr to automatic..( i guess this reduces block noise? max. 3000 and min 1000) used fps 23:995
What am i doing wrong? Please advise
maybe this should be moved to the advanced conversion?
If anyone could help thanks. -
If you changed the bitrate setting from CBR to something else (VBR?) it is no longer VCD compliant. Re-encode the video with the standard template and see if that fixes it. It is quite likeley your DVD player cannot handle mpeg-1 at higher bitrates.
ok ill give it a shot..thanks
Do you think if i change the resolution/pixels would it ge rid of some block noise/ -
Dont change the resolution either, again it would be non-compliant. Make sure you can create/play fully compliant VCD's before messing with settings. If you want to reduce block noise there is a tick box to enable this option in Tmpgenc on the Settings->Quantize Matrix tab, try that, but it will reduce picture sharpness too.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
