Hi,
I followed the guide from
http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs/
Everything works fine, only how can I add subtitles to my project in MyDVD.
If you encrypt the files with smartripper like it is in the guide the files are with extension .rawsub.
This can not be imported in MyDVD. Is there any program that convert those files or is there another way to have a DVD ripped to a DVD-R with subtitles. (so I can play it on my PS2)
Forget it... this piece of crap (MyDVD) can hardly find its own ass, let alone do complex DVD authoring stuff. It allows MENUS and MOVIE - I don't even believe that it supports Digital Dolby (.AC3). It has no facilities for importing a subpicture stream.
forget about DVDit then. Do you know any way to use Smartripped .rawsub files for ANY authoring software? I've read all of the FAQ and howtos and they only tell people how to rip the close capture out from the movie and re-create the subtitle files. That only works for English subs.
The .rawsub files are there for many languages, Japanese, Chinese, and many others that cannot be recreated. Isn't there a utility for convert the .rawsub files for some authoring software? I know all authoring software takes only certain type of format forthe subs. Just need to know if anyone EVER able to use the .rawsubs for ANY authoring software.
Add DVD Subtitles to a BlueRay
By wulf109 in forum Blu-ray RippingReplies: 3Last Post: 16th Mar 2014, 17:53 -
How to add watermark when DVD Ripping - StaxRip
By antonymaheshca in forum Newbie / General discussionsReplies: 9Last Post: 19th Dec 2010, 08:13 -
Is it possible to remove subtitles from one dvd and add them to another?
By nouseforaname in forum EditingReplies: 2Last Post: 16th Jul 2010, 15:54 -
How do I add 1 or more subtitles in txt form to a DVD rip to DVD?
By JoeBolden in forum SubtitleReplies: 8Last Post: 15th Nov 2008, 02:22 -
How to backup and add new subtitles to a DVD
By Paddington in forum User guidesReplies: 73Last Post: 6th Oct 2008, 22:19
