i am considering a dv camcorder purchase very soon and want to get the video onto my pc , i understand a dv capture card is required and firewire cable , im not bothered about software right away as i can download trials to use at first , i was wondering if the Dabs value card and cable costing £15 is good enough or is the any quality issues with a cheap card and cable ? If so please tell me why .
Its easy to take the easy route and buy a kit but this is not always the most cost effective or best option .
If there is a better card/cable i should use please let me know , i will also be wanting to edit my 8mm tapes through the dv camcorder as i will be buying one with analouge in .
all advice is greatly appreciated .
Results 1 to 1 of 1
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 23:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 23:10 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 11:28
