I am currently converting some DivXs to XVCD format and used BitrateCalc to come up with the necessary bitrates and resizing of the image.
I used the standard VCD resolution but wanted to use the 720x576. Unfortunatlly when I created a small test file, it did not play correctly at all on my DVD. I figured that it was cos the DVD couldn't handle it.
However, when I used nero to burn my XVCD I created a small menu just to see how it would go. When I looked at the Mpeg/track that nero made called 'Menu' it had a resolution of 720x576 and it displays correctly. Why is this. Is it because it is not a full motion Mpeg or did I do something wrong when encoding my test?
Thanks for any help.
P.S
How should I archive a 1.5Gb DivX onto CD. I need to get it of the machine to free up space.
Results 1 to 1 of 1
Converting DV 720x576 with AR 16:9 to AVC using libx264 and FFCoder
By klode in forum Video ConversionReplies: 3Last Post: 11th Dec 2011, 10:57 -
blu ray player says video larger than 720x576
By PSS2 in forum Authoring (Blu-ray)Replies: 4Last Post: 4th Jul 2010, 16:07 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17 -
720x576 avi files lose their aspect ratio when played on DVD player
By tzikeh in forum Authoring (DVD)Replies: 1Last Post: 24th May 2007, 02:47
