  1. YEs i'm a newbie
    I'm wondering about divx ecoding, i see when you want to encode ou have several options with the codec, i was wondering what the difference is between 1-pass vs 2-pass and so on, does it give you better qaulity if you do 2-pass???
    Thanks again
  2. There are various guides available for Dixv encoding. I suggest you do a search. But to answer your question....
    Yes. the second pass option would output a better quality rip at a smaller file size. Please note that this would double the amount of time required to create a rip.
    D
