Ok my 1st question i downloaded an mov i cant open it in is in tmpgenc. I downloaded the plugin on this websit but its still not working i put the lil file plugin in the same folderas tmpgenc still no luck. Is there any way to convert an mov? I also tried the MOV2AVI GUi on here, that too doesn't work.
And my 2nd questoin in vcd easy i did what you said on this site to turn that cdrado integration on and it worked. now when i try to open up vcd easy my pc goes to that error blue screen it says no cdr or ASPI DRIVER can you help??
thanks so much you guys are the best!
2. download and install aspi -> http://www.nu2.nu/aspi/
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 04:44 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 08:07 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
Easy to Use DVD Convertor
By booyaka in forum DVD RippingReplies: 3Last Post: 8th Feb 2008, 19:20
