Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    May 2002
    Tacoma
    Ok, I am so frustarted I don't know what to do. I am getting <1% frame droppage and I good clean signal. Why is it that everytime I try to capture to DivX using the method in the capture guide, the audio and video are out of sync? I even try to fix it according to the intructions.........nothing. When I started doing this a few weeks ago, no syncing problems at all. Now, every @#%ing time I capture the audio tends to run faster than the video. If I capture at 29.97fps the video will be 29.971 and the audio will be something like 30.017. Then I pick the option to make audio and video durations match and that makes no friggen difference. To be totally honest, this doesn't make any damned sense and I am just ready to say @#$% it!!!!!!
    You want the truth?!? You can't handle the truth!
    May 2001
    Eric
    Just a thought, when you said a few weeks ago you didn't have any problems, have you checked the obvious stuff? Is the disk defragged? Closed other applications?
    May 2002
    Tacoma
    Yeah, sometimes I don't have any problems but most of the time the sync is terrible. I have defragged my hard drive 3 days ago and I make sure that no other apps are running before I capture. I usually get <1% frame droppage when I capture at 29.97 fps, especially from a DVD. But when I capture from VHS or TV I usually drop >1%. But I capture at 25 fps and it is still the same so, to save on memory I capture at 25 fps from TV or VHS. It's weird though, when I capture using huffyuv, no problems. Then I encode to DivX ;-). But, if I want to capture a movie, I am forced to try capturing to Divx ;-) again because of memory constraints. I guess I could just capture to huffyuv in parts and then just join them after they are encoded to DivX ;-). I just want to fix the problem. This shouldn't be happening anyway. It's weird, I know, but if I could nail down the problem that would be awesome. Thanks!
