Given the same resolution, is SVCD any better inherently than XVCD at the same bitrate or is the difference only the format specifications?
There is no inherent quality difference. But you can encode SVCD as interlaced, which of course gives much better quality if the source is interlaced and the bitrate is high enough.
Thanks for the answer.
That's good to know.
It would be nice to find out how TMPGEnc double-lines originally interlaced sources to generate MPEG-1 progressive video.
Then that could be compared with a 540p or 480p HDTV-ready TV and see how you get the best results. I'll try the that when I buy one.
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 15:42 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
What's the difference in quality between SP & LP modes in MiniDV??
By navi310 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jun 2007, 11:09
