hi, i was trying to convert an Svcd to Vcd, i've done all the encoding and stuff, but when i try to burn it on to cd using Easy CD Platinum, it says "System Clock Reference Error" and doesn't create the vcd. Anyone have any ideas on how to fix this problem??
Look at using another burning program - EZCD has tight specs and isn't user friendly.
VCDeasy is freeware & may work for you. Nero you have to buy but it'll burn anything.Panasonic DMR-ES45VS, keep those discs a burnin'
H.264 reference frames
By grinder_luck in forum ProgrammingReplies: 1Last Post: 13th Jul 2011, 11:39 -
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 12:34 -
sync computer clock to broadcast?
By 4evrplan in forum ComputerReplies: 5Last Post: 9th Jul 2008, 15:36 -
Fall for Recorder Clock
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 8Last Post: 12th Nov 2007, 09:06 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 14:20
