I tried using virtualdub, as described. But it doesn't work. Only the 'time elapsed' box keeps ticking, with the other descriptions having no reactions at all; profected file size as unknown, video rendering rate as 0.0, total time estimated as N/A.
Can someone enlighten me...
Same problem here. And if i set the point in audio to direct stream copy, the file gets bigger than before.
Do you know any help yet?
Thanks -
No, haven't found any help yet. But at least now I am glad to know that I am not the only person having this problem... So that means the problem is not due to my computer. -
you dont really describe your problem very well, but look to the left of this page and you will see a section labelled "HOW TO". It is very likeley your problems will be solved within one or more of these guides.
Are you sure your MPG is MPEG1? Virtualdub doesn't do MPEG2.
Videostudio 6 or MediaStudio Pro or Premiere will handle the MPEG2 conversion. Trial versions of first 2 at www.ulead.com to test it out.Panasonic DMR-ES45VS, keep those discs a burnin' -
I did read the 'how to convert.' I downloaded virtualdub already. I used the settings as suggested. But cannot go anywhere...The software just does not 'convert' anything. All it does is create a new file (with the file name as my avi file name), but the file size is 0KB.
problems with VOB to MPG conversion
By Created78 in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2009, 12:20 -
Problems editing an mpg in premiere
By PharmBoy in forum EditingReplies: 7Last Post: 13th May 2009, 13:30 -
MPG transport stream problems
By drwho in forum Video ConversionReplies: 4Last Post: 15th Dec 2008, 20:54 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 21:35 -
Having problems with MPG-HD to MKV
By SpydaMan in forum Video ConversionReplies: 10Last Post: 25th Mar 2008, 21:37
