Hello,
First off, let me say thanks to all the knowledgeable people on this forum, because without certain tips, I could not have done it in such an efficient manner. My apologies to the experienced users who already know what I am about to shareMy configuration:
Athlon XP 1600+
512MBSDRAM
60GB Crappy HD
WinXP Home![]()
AverTV Stereo Card -> $49.00!
Here goes! I use the software that comes with the card for capture. I capture in this mode: 352x240 at 6x VCD bit rate, which is 6912K using MPEG1. I do this because uncompressed AVI is simply ridiculous given my config. I believe this works out to about 50 or so MB/min - 3GB/hr disk space, which is perfectly acceptable. This step is necessary because the VCD capture format in real time looks truly dreadful. Six times VCD bit rate is necessary to survive the re-encoding process intact. Try capturing at 2x VCD resolution and use this method, and compare so you can see what I mean. I take this file, and using TMPEGenc with the noise reduction (crappy cable signal) and sharpen options selected, do a conversion to VCD format. On my machine, it takes approx. 2.25hr per hour of video. Use nero to burn to CD, and voila! My wife saw a disc I made from the Star Trek marathon on Sci-Fi yesterday, and said it looked quite a bit better than the same episode I taped with my VCR! The benefit of this approach is that I did not pay for anything other than my tuner card $49.00 and a copy of nero ($10.00)OEM! I hope this was useful.
TomG. - aka Plant_Guy
Tom - I saw the AverTV card at the local Circuit City - can it do higher capture rates well? MPEG2 possibly? My machine is not bad (see specs above).
Thanks, Da KittyPanasonic DMR-ES45VS, keep those discs a burnin' -
Nice setup kitty
I've tried the 640x480 setting without seeing any frame drops, and my CPU is nowhere near full load, so yes, you can capture at DVD res., and mpeg2 with your rig (Ithink). The reason I capture to mpeg1 standard is that TMPEGenc barfs when I try to open a high bitrate mpeg2 formatted stream. Why this is, I do not know. Also, I might point out that for whatever the reason, the AverTV software uses much more CPU horsepower with the mpeg2 codec. When I compare the output from this card in mpeg2 and mpeg1 at high bitrates, I perceive no real difference in quality, so I use the mpeg1 format. Hope this helps.
TomG. - aka Plant_Guy -
Do your videos have any a/v sync problems? I have the AverTV Stereo card and I am trying to decide whether it's the TV card that is causing the sync issues I am having.
Thanks,
calamari -
I just captured the HBO special on the sept11 events, and there are no sync problems.
decent vcr replacement
By yuhr in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2009, 13:06 -
Looking For A Decent Camcorder Under 200$
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th May 2009, 12:13 -
Finally some decent deals from the Circuit City "liquidation".
By Xylob the Destroyer in forum Off topicReplies: 4Last Post: 27th Jan 2009, 18:34 -
LG DN788 not read VCD?
By joselect in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2007, 14:04 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
My configuration:
