How Do you Conversion AVI Files to Burn to DVDR
The basic steps are
Convert the video to dvd mpeg format
Author, make chapters,menus and create the vobs from the mpeg
And last burn it.
You could let your authoring software do it all for you, if you have for example sonic mydvd or dvdit just add the avi and it will convert,author and burn it.
Or you could convert with tmpgenc to dvd mpeg and then author and burn the dvd mpeg with your authoring tool. With this method you have much more control over all settings when converting to dvd.
www.vcdhelp.com/tmpgencdvd.htm
www.vcdhelp.com/author.htm#dvd -
Thanx for Quick Responces~
Is there a Tutorial for MYDVD
or
With TMPGEnc How do you use it with 2-3 Avi files then Burn to DVDJayDot~..........
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
copy avi file from scratched dvdr
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2010, 01:14 -
AVI file(s) too large for DVDR
By sybarite in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 20:35 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 05:09 -
HD Mpeg2 Conversion for DVDr use on HDDVD players
By dildatron in forum Video ConversionReplies: 3Last Post: 25th Jun 2007, 18:09
