In Ulead's DVD Workshop, whenever I try to select a menu template or use the menu wizard, I get an error "unsupported operation," and then the program halts. If I use the "blank" format, it's OK. I have downloaded the extra content file. Looks like the templates are there in separate folders.
Anybodybody else come across this? Thanks.
I don't know if this will help but...
I had a problem with the app locking up on the menu page, and turned out it was because I was using TightVNC (allows me to use the computer remotely). After disabling that, it worked fine. While waiting for an answer from someone more learned you may want to experiment by shutting down windows tasks one by one and see if that solves the problem. -
Originally Posted by jollyrodger
I'm getting the same problem, only a little worse (see, some of us DO search the old threads before asking).
When I try to use the menu wizard or a standard template, I get that "unsupported operation" message, then the Windows "Ulead DVD Workshop has encountered a problem and needs to close" message, then DVDWS aborts.
When I try to use a blank menu and build it from scratch, I add my buttons and my movies, then when I go to "make disc," I get an error message telling me there are no buttons in my menu.
I did NOT have this problem the previous time I had DVDWS on this computer, back in June.
So anyone know what's up with this?
Thanks....
Subtitle Workshop Crashes
By randy3101 in forum SubtitleReplies: 5Last Post: 6th Jun 2012, 15:32 -
subtitle workshop crashes when loading video
By stem300 in forum SubtitleReplies: 0Last Post: 29th Dec 2011, 15:37 -
Subtitle Workshop crashes upon loading subs
By mystic818 in forum SubtitleReplies: 9Last Post: 17th Mar 2011, 06:51 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 06:57 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 07:12
