I've always used an older version of TMPGenc (12f) which seems to do everything I need. However, I've come to realize that when I use the MPEG tools, it almost always screws something up.
For example, join two file both with good audio sync, the resulting file has poor synching after the join.
Multiplexed sound to an mpeg2 file and the resulting file showed motion squiggles after buring to DVD. Files before and after were encoded with TMPGenc, not multiplexed, and look fine.
So my question: do the newer versions work properly and make it worth changing? Thanks for any input.
They work fine for me. I'm using the latest version. I can still get it to lock up occasionally cutting mpeg2 if I try to alter the position using the vertical arrows in the range setting - so I don't! I use the slider and/or enter the time. 8)
Did U do these changes
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
I dunno why but it seems it depends on the architecture and clockspeed used.
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 17:26 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 12:58 -
Not being able to rip BD with newer versions of DVD FabDecrypter6.2....
By cal_tony in forum Blu-ray RippingReplies: 6Last Post: 13th Nov 2009, 07:47 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 22:38 -
Can't get the .TS audio to work properly
By mkvbob in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 17:04
