My Dv video files are Cupter from my Mini-Dv Camcorder at 3500 Kbps (+/-).
When i convert it to DVD, Is it reely useful to convert it to higher Kbps ?
( Somsing like 4000 Kbps / 6000 Kbps Or 8000 Kbps. )
If I understand right, it's can't by better from the source video file.
Thanks,
Ofir
ofir@agam.co.il
Results 1 to 9 of 9
minidv is about 3500 kbyte/s while dvd is 4000-6000 kbit/s = 500-750 kbyte/s. So you will convert it to a lower bitrate but with another compression technic so you won't lose that much quality.
1 bit is 8 byte. -
Baldrick hi,
What You'r saying is thet DVD quality is about 1/4 then Mini-vd ???
Thanks,
Ofir
ofir@agam.co.il -
Not the quality but the filesize.
And DV correctly is 3.61 MB/s ~ 3.700 KB/s ~ 30.000 kb/s.
If you have a mpg-stream with 5.000 kb/s then you have 1/6 filesize but much more than 1/6 quality.
regards
mb1 -
Actually, 8 bits is 1 byte (but we really knew what you meant!).1 bit is 8 byte.
So, if i don't want to lose any quality what seting you suggest ???
Thanks,
OFIR
ofir@agam.co.il -
TMPGEnc 6000kb CBR, Highest Quality (slowest). That is what I use and seems to be 1:1 as much as possible. If you want to cut down on file size there is a method you can do in CCE.
And I would just suggest 6000 VBR, not CBR, with maximum bitrate being 8000 and minimum being 4000. The final file size may be lower than CBR (not all your frames may need allocation of such a high bitrate), but the quality will rule! Especially if you use 3-5 passes with CCE.
"There is always one more bug."
No bugs at http://www.iGorland.com -
That is just in TMPGEnc I was suggest and yes in CCE it would look much better.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
VHS to DVD - 3 questions (encoding & bitrate)
By spup345 in forum Capturing and VCRReplies: 21Last Post: 17th Sep 2010, 21:39 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44
