Hi Guys,
I just subscribed to this forum and needs help.I used DVD2SVCD for the first time and was unsuccessful.At the end of the conversion,all I got was an avisynth.vpafi.avi file(I did not get any mpeg file at all to burn to my cd-r).When I played it using windows media player,the film was jerky and has no sound.Below is the text log:
- 5/26/02 10:11:20 PM
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.0.9 build 2
Initializing
Initializing finished.
- 5/26/02 10:11:23 PM
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Program Files\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[C:\Program Files\DVD2SVCD\Movie\vts_03_1.vob,C:\Program Files\DVD2SVCD\Movie\vts_03_2.vob,C:\Program Files\DVD2SVCD\Movie\vts_03_3.vob,C:\Program Files\DVD2SVCD\Movie\vts_03_4.vob]
Analyzing DVD2AVI Project file
Force Film activated!
Framerate: 23976
DVD2AVI processing done.
- 5/26/02 10:26:27 PM
- Free on drive C: 12182.31 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Audio1 delay: 4 ms
Audio extraction finished.
- 5/26/02 10:46:41 PM
- Free on drive C: 11860.05 mb
- AUDIO conversion
Converting Audio to MP2. Filename: C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3" -output "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.mp 2" -logfile "C:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -g max ) -ota( -d 4 ) -2lame( -e -b 128 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 5/26/02 11:39:19 PM
- Free on drive C: 11767.97 mb
- Video Encoding using Cinema Craft
Executing Frameserver.
Closing program
Executing Cinema Craft Encoder.
StreamSectors: 1667869728
AudioSectors: 97931036
VideoPAPO: 24319188
ScanOffsetBytes: 173603
SeqAligningBytes: 11033422
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 1534412470.80
Seconds: 6038.91
CalcMPEGStream: 1534412470.80
Frames: 144669
CDSize: 800.00
Cut point 795.00
Variable Settings:
Frames: 144669
Anti Noise Filter: Off
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 1150
Max. bitrate: 1150
Avg. Bitrate: 1150
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1 .DLL")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2DEC\MPEG2DEC .DLL")
mpeg2source("C:\PROGRA~1\DVD2SVCD\MOVIE\DVD2AV~1.D 2V")
SimpleResize(480,360)
AddBorders(0,60,0,60)
----AVS End----
I carefully read the instructions but I don't know where I have gone wrong.Please help.
Thanks a million,
I AM I
what in the world are you trying to do? DVD to VCD or XVCD or SVCD or what? your bitrates are for VCD yet your doing a VBR encode with CCE? That's all whacked. Tell me what your trying to do. see dvd2svcd.org for recommended bitrates for svcd or vcd. Also be sure to rip with internal routines.
Min. bitrate: 1150
Max. bitrate: 1150
Avg. Bitrate: 1150 -
Dear Mr. Bass,
Thanks for your time reading my log.I was trying to make DVD to SVCD.Sorry if my settings may not be correct.Shall appreciate some tips.
Thanks,I AM I -
you could also try www.doom9.org and goto their forum. there is a forum titled DVD2SVCD basic topics and one titled DVD2SVCD advanced topics. http://forum.doom9.org/forumdisplay.php?s=&forumid=47
http://forum.doom9.org/forumdisplay.php?s=&forumid=34
also, did you try to recover the project. sometimes when it fails for me whereever I can just goto misc and recover it and it will start back up right where it left off. -
Thanks jledhead.I already went to this site and read the docs.I think I knew now what went wrong.I did not try to recover but deleted all files instead.I have started all over again and so far,looks everything is running fine(without any crashes or message errors).As of this time,the prog is still encoding.Is it normal to finish the whole thing for 14 hours?I set to 3 pass VBR.I thought CCE is much faster than TMPGENC.I think I will stick to VCD next time as it only takes approx. 8-9 hours to make a VCD.Thanks for your input.Originally Posted by jledhead
Regards,I AM I -
yeah it can take a while. 3 pass vbr means it created the vaf file, then 3 passed the movie, so 4 passes in all.
but check out the link below
http://forum.doom9.org/showthread.php?s=&threadid=13435
its a good way to do 1 pass and the quality comes out nice, with only about 3 hours to encode -
Hi,Originally Posted by jledhead
This link is great!Thanks once again.I will try these settings the next time.
Best regards,I AM I -
ok...well if it's SVCD your bitrates are set for a VCD I sure hope you changed them approriately.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
