  1. Hi.
    I have a question and I really hope someone can help me.
    I live in Brazil, and I have this capture card: Pinnacle Studio DC10+.
    The problem is that our color system isn't NTSC or just PAL. it's PAL-M.
    I am unable to capture stuff in PAL-M.
    And mostly of the stuff i want to capture is PAL-M. So, is there any software that i can use to capture it in PAL-M? or will I have to buy an external conversor? I dont mind to buy one since it works. So, any idea where can i get one?
    thanks
    Daniel
  2. I think if you record into NTSC, it will work fine.
    May 2002
    australia
    I had some ntsc tapes that my vcr recognised as PAL60 format. I used virtualdub to capture them with an aver studio card (b878) and latest btwdm (b878 wdm) drivers. Hope this helps.
  4. Eu tenho quase certeza que você vai ter que comprar um conversor de pal-m para ntsc e esse conversor é um dos mais caros (por exemplo o de ntsc para pal-m é mais barato, mas não serve para você). Um amigo meu teve o mesmo problema que você. Ele tem uma DV500 e não conseguia capturar nada em pal-m, mas o problema maior é que o vídeo que ele usava não era Ntsc puro. Eu tenho a placa miroDC30 e ela consegue capturar diretamente o video em qualquer video e em qualquer sistema.
    Boa sorte
  5. Don´t spend your bucks ...work with NTSC ... almost same quality but big compatiblity with any DVD player (Gradiente , Philips ,Philco, CCE, Panasonic, LG ,...). If you capture TV shows ,soap operas or other craps , do it with NTSC . This means 29.97 fps and NTSC standard resolutions.
    I do this way...
    May 2001
    Bolton, UK
    PAL M is not NTSC or even an hybrid format it is a PAL based format using a different colour sub carrier 3.575611 Mhz with some characterises of NTSC i.e 525 lines and 30Hz
    If you capture card has a Brooktree fusion 878A or 878 chip you could try the following drivers http://sourceforge.net/projects/btwincap
    Failing these you either need to buy a capture card for you country or a multi standard VCR
    or a standalone converter
    May 2001
    Bolton, UK
  8. Hi,
    If the hardware doesn't handle the PAL-M standard there's no way without loosing quality to capture with a board with only NTSC.
    A board, easy to find, that captures in problably any standard is the cousin board PCTV from Pinnacle (brazilian version). I guess for general use it has enough quality and costs less than US$100,00 in Brazil. It has S-VHS input and RCA. I use to capture at 720x480 very easy. It uses the Booktree 878
    Believe me, at the cost of a color converter you can buy the PCTV.
    Aside people blame the PAL-M standard, in analog way it's the best color system. European variants use 50Hz refresh rate that can cause flicking. With M frequency standard, PAL-M doesn't flick and have soberb colors.
