Hi.
I'm not the only one that has downloaded a DivX file with an AC3 audio track and got stuck.
Fortunately searching this Forum will get you the answers you need to solve the problem.
I just want to make a small addition / suggestion to the "guide" so skillfully made by Stinky :
If HeadAC3he won't work for you (it didn't for me),
try px3conv_004 to convert the AC3 to PCM.
(h**p://www.digital-digest.com/dvd/downloads/ac3towav.html)
Not so fancy but it does the job.
I hope I did not offend anyone.![]()
The Larch.
Results 1 to 1 of 1
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 16:48 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
