After TMPGEnc ran out of mpeg 2 trial i've not been able to get SVcds of music video clips looking as good. What are the best settings in Adobe Premiere? I got a great picture for music video clips in SVCD but now i'm stuck!![]()
cheers,
Hi! I've read your problem regarding TMPEG expired SVCD trial version. I too, am looking for the full free version but could not find it. You said you found it in Kazza, but could not find it there. Can you tell me where to go? Is it also free? Thank you.
There's a full version on grokster. dont download the crackovision one however as that one doesn't work. make sure you download the one called tmpgenc+crack i tried it and it works!
Well the cracked version I downloaded worked. I'm using Kazza lite if that makes any difference. And the file is called TMPGEnc Plus 2.54a.37.135 =FULL.exe Maybe you need to change your options because you've proberly got the filter on.
I've looked for that crack but with no success. Can you be more specific if poss?
carpe diem maņana
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Premiere MPEG for DVD setting
By CircusAim in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2010, 12:23 -
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 20:29 -
Weird frame rate issue. Anybody ran into this before?
By dimtim in forum Video ConversionReplies: 4Last Post: 19th May 2008, 08:21 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48
