Whenever I try and add the mpeg file in the VCD creator i get a message that says "you will nedd to use and mpeg encoder that is VCD compliant" It also says that my video bitrate and and system clock refernce are not acceptable. I would appreciate any ideas on how to fix this problem.
Chase
I would suggest using another program like Nero that will allow burning non-compliant files.
If you really want to use EZCD, possibly for the menus, there is a way to 'trick' it into burning non-compliant files. I didn't come up with this, but I forget who did - credit goes to them.
Create a compliant file that EZCD will accept, and name it say 'dummy.mpg' When creating the menu structure in EZCD, point the program to dummy.mpg. When you're done setting up the menu, just before you begin to burn, go into Explorer, rename dummy.mpg to something else, say dummy1.mpg, copy the non-compliant mpg file (the one you want to burn) into the same directory as dummy1.mpg and name it dummy.mpg.
EZCD only checks for compliance when creating the menu, not when processing the file(s) to be burned. At that point, you can either save the project, or burn and it should go fine. Of course, for multiple mpgs, you would just create multiple dummy files - it can get confusing working with a lot of files, so take your time.
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
