Hello, i need help..
i have AVI(DIVX) and i want to convert it to mpg, i have trying using virtualdub and also tmpeg but when i use tmpeg, it said error... why does TMPEG can;t open the avi files.. but some of the avi files, can open it..
can anyone help me?
how to convert divx (avi) to mpg with easy? so i can burn it as VCD
Thank You..
me spice sonic
Ok, I had this same problem. I also had to search far and wide for the solution on some no-named message boards. But anyways, here's how to fix that little problem. While in TMPG, go to options, then enviromental settings. Then click the tab VFAPI plug-in. There should be a list of things there and to the right of them, a certain value. It's the priority of the job specified. Set all the priorities to 0 except DirectShow Multimedia File Reader. Set that priority to 2. You can lower and raise priorities by right clicking in the priority column box and then clicking lower or raise priority. I hope this helped you. Everything should work now!
MPG Time Length Error
By Joorrdaan81 in forum Newbie / General discussionsReplies: 2Last Post: 4th Nov 2008, 16:47 -
Getting error loading mpg that svcd2dvd created
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Oct 2008, 13:14 -
WMP11 Error on .mpg and .mpeg playback
By peebee23 in forum Newbie / General discussionsReplies: 14Last Post: 11th Sep 2007, 14:27 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
