hi ppl
i'm trying to figure out whats going on with tmpgenc V2.54. everytime i go to start the encoding this window pops up with "can't load p3package.dll" ? i've tried to unistall and reinstall but the samething happens . can someone help me plzzz.?
thank you
there should be 2 .dll files p3 package.dll and p4package.dll in the tmpgenc folder check if there there if not you need to download it again.what do you mean install whats to install.
i have the 2 dll files downloaded . i tried to reinstall tmpgenc because i thought it was missing that dll file but the samething happens . i'm at a lose , i seemed to have done things correct from d/l to extracting the files. oh i also tried extracting that certain file only but still comes up the same . i can see it on my pc but just can't seem to get tmpgenc to work .
is it posible that it has to do with the regeistration on tmpgenc? because mine expired so they say.
thank you
dave -
This is simply downloading or unzipping problem.
Some unzip software ignore the original file/folder structure, then the dll is extracted to wrong place.
i did try and extract the whole thing and it didn't work then i tried to extract just that file and that didn't work . i can try again, and should i delete everything then reinstall tmpgenc and unzip , or just unzip from where i am ?
but one thing i see the dll file near my tmpgenc file but it didn't work . -
Had same problem. Ensure that the program is opened from within the directory containing P3 file or using a shortcut to it...Cheers
Love makes the world go round
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 18:55 -
Computer keeps trying to load some weird ntload.dll file
By jyeh74 in forum ComputerReplies: 40Last Post: 28th Dec 2009, 09:41 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
AutoMKV problem, warpsharp.dll failed to load
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 09:32
