Results 1 to 9 of 9
  1. Is there a way to cleanly rip the MPEG2 file from a SVCD?
  2. What about copying the MPEG-2 file to your HD? Is that clear enough for you?
    Visit my webpage at:
    http://leech.at/e-z-e
  3. I tried that, but the file doesnt play... dont you have to do something to the file?
  4. in which player do you have this problems ?
    i guess it is windows media player!
    check the Tools page in vcdhelp and download the svcd codec
  5. I have MPEG2 files that I use just before I burn an SVCD and they play just fine in WMP.. but when I try to take a file from an SVCD it doesnt work.
    I have Power DVD installed so I shouldnt need the codec..
  6. Try downloading the newest version of VCDgear. After extracting the MPEG-2 file to your harddrive run it through the error correction fucntion. Maybe there is something wrong with the file?
  7. Thanks.. VCDGear did the trick.. odd.. it said something about a Pack error.
    The video was encoded in TMPGEnc and then burnt to SVCD using Nero, so who knows what happened to the MPG file..
  8. Hi
    I have a simialar problem.
    When ripping a DVD and then converting to SVCD and splitting I can play the MPEG file on the PC but as soon as I burn it to the disc it becomes unplayable on the PC BUT will play on my standalone DVD player?
    If I try to copy the MPEG 2 file back from the CD I get ' illegal dos function' or something. If I try and play it in Power DVD it get a not suported format.
    Any ideas?
  9. The problem that you are having is that all MPEG2 files are reformatted when they are burned on to a SVCD. It is still a MPEG2 but not recognized as such by Windows Media Player.
    To fix it you need to do a simple multiplex with the SVCD file as the video and audio source. The output will be a MPEG2 formatted for your PC.
