I'm trying to capture all my U2 music videos and create a standalone DVD player-compliant DVDR with menus using DVDit!, DVD Maestro or SpruceUP. Here is my general plan:
Capture video at 720x480 with ATI Radeon 64MB VIVO and Virtual Dub using Huffy codec. Capture sound to an uncompressed file. Use TMPEGEnc to encode the video using the template found on this page: http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
Compress uncompressed sound file to AC3 format.
I'd like to fit about 160-170 minutes onto the DVD-R. What bitrate should I set TMPGEnc for? Does anyone have any other suggestions or comments? Does this even seem like a feasible plan?
For 170mins of video ull need a bitrate of about 3000- 3300 at most.
and u might wanna soften block noise in quantise matrix tab on tmpgenc -
I should mention that I am capturing from VHS tapes and I'd like to get a DVDR that is compatible with non-VCD compliant standalone DVD players.
Authoring so that my standalone DVD player can respond to remote control
By cprelude in forum Authoring (DVD)Replies: 3Last Post: 22nd May 2008, 13:03 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Why is my movie not DVD compliant?
By johnharlin in forum Video ConversionReplies: 19Last Post: 3rd Jan 2008, 22:11 -
Movie freezes after authoring compliant DVD files
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 21st Dec 2007, 11:29
