I encoded a .avi file to a .mpg file to make a vcd. in the vcd portion of my cd burning program, it said that file was 42 mins and 2 seconds. in windows media player, though, it said te file was 23 minutes and 30 seconds. also in the cd burning program, it sais the file was 397 megs but in the actual directory, it is 427 megs. i also tried to edit it to see if i could edit it and inside the movie editing program, it was the full movie (42:02). what will it be if i put it on a vcd?
Go with what the CD burning program said...WinMediaPlayer some times reports wrong lengths ..IE said file was 2 minutes but will play all 30 minutes... The Burner Program is also right on file size.. It uses its own method of calculating bits...So if it says a file is 400mb and that you have a 703mb disc...Its right or at very least consistant which is all it needs to be..
Buying a new UPS (no break)
By Caple in forum ComputerReplies: 6Last Post: 12th Dec 2010, 10:26 -
mp4 convertion
By ht0160 in forum Video ConversionReplies: 2Last Post: 15th Feb 2008, 01:09 -
2D Shoot Em Ups on X-Box360, PS-3, Wii…
By retroborg in forum Off topicReplies: 7Last Post: 7th Jan 2008, 05:42 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 00:50 -
Do you have a UPS backup for your Computer?
By yoda313 in forum PollsReplies: 51Last Post: 25th Jun 2007, 19:48
