I'm in the UK but I want to capture from an NTSC source. I have an ATI All In Wonder 128 which I'm using fine for Pal captures so I'm looking for something that is either external (paralel/usb) or a PCI card that is capture only so it won't conflict with the ATI. I'm assuming that I won't find a UK product that will do NTSC capture, so is there a budget US one?
I'm only looking to capture imported NTSC films to VCD so that I can purchase films not available in the UK, so it doesn't have to be very powerful(?).
i think is easy to change the capture ntsc/pal or pal/ntsc with your capture software(ex: video studio).
is it a solution for your problem??? -
Thanks, but it seems that the ATI AIW is manufactured as either NTSC input or Pal/Secam as none of the software I've tried will allow me to capture in NTSC.
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 03:35 -
External analogue capture device to stream to Livestream/uStream etc
By batfastad in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Jul 2009, 07:59 -
Pal-60 Compatible External Capture Device?
By Justin-NZ in forum Capturing and VCRReplies: 6Last Post: 22nd May 2008, 11:30 -
external capture/convert device - use a camcorder?
By travman63 in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 12:29 -
Should I get a new camcorder or an external capture device?
By steppenwolf_27 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jul 2007, 15:36
