I am trying to convert Divx files to xVCD format. The divx files are about 230MB and are about 43min long. When I try to convert using TMPGEnc. using the following settings I get a file that is over a Gigabyte in size! It gets to the end of the video and then shows the last frame for about an hour. I don't know what I'm doing wrong and it was working before.
Stream-Type: MPEG1 Video
352x240
4:3 525 line
29.97 fps
Constant Bitrate(CBR)
Bitrate 1024
vbv buffer size 40KB
It doesn't matter if I use highest quality or lowest, they turn out the same. Any sugestions?
My hardware:
850 Duron
Iwill KK266 mobo
Radeon 7200
That sounds a bit strange?
An average 750mb DivX converted to VCD using 2 cd's will come out between 1.2 to 1.5 gig (split over 2 cd's...600-750mb...depending on bitrate).
I would be suspicious about that last few seconds taking so long to encode.
Did you play the AVi in Media Player ok?......
Does that same last minute part of the movie play ok?..
If you suspect a problem try these tools..
DivFix or even better go here and download the special version of Virtualdub called Mp3 Freeze
http://www.digital-digest.com/dvd/downloads/virtualdub.html
(remember to scroll down the page till you find the right v-dub)
...then open movie > Check for freezes...and then check the Notepad log of all the bad frames .Then extract them and re-stream the movie in V-Dub."Today is only yesterdays tomorrow" -
Sorry I wasn't clear. It is not that the last frame takes a long time to encode, it's the last frame is over an hour long when playing back. And I just noticed there is no sound.
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Problem with 1024, 1280 width
By kailmursili in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 06:22 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 01:20 -
AVI to MPG: Optimum bitrate?
By NDMMackay in forum Video ConversionReplies: 10Last Post: 12th Oct 2008, 10:03 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 12:47
