  1. Hi, I'm pretty new, and am having trouble encoding Computer Animated films with TMPGEnc. All others work fine. When playing the video it is garbled with color blocks everywhere but the audio is encoding fine. I'm sure it is just a setting that I need to change. I'm just not sure what. I've messed around with it to no avail. Any help would be appreciated.
  2. You might try fiddling with the Quantizer Matrix in TMPEG settings. It is normally set to a standard setting but there is one there for CGI Animation.
    Don't know if it'll make a difference for your stuff but its gotta be worth a try.
    Good Luck,
    Ian
