  1. i am using "dvd2svcd" with cinema craft encoder and ripping dvds ...the quality is pretty good ...but it is a little blocky at times and pauses and cuts out here or there...i was reading some of the posts .will the blockiness improve if i change the vbr multipass? right now it is set at the default of 4 ....if not what could i do to improve that?
  2. anyone know the answer?
    I have blockiness with CCE also on fast scenes, with nearly everything setting I've tried. you may have to use TMPG CQ mode.
  3. VBR is optimal around 3 or 4 passes though I'm wary to give advice on how to fix blockiness.
  4. Soften block noise in TMPG, or Anti Noise Filter in CCE
    Test with different values.
    Sep 2001
    N/A
    whats your source?
    Is it avi?
    If its a bad avi it will look like that but dvd2svcd with dvd and cce at 4 pass should look great.
    Baker
