hi guys,
im a newbie to this forum and a newbie to CCE, but not Tmpeg.
My problem is i recently got CCE and was impressed how quick it encoded, but the aspect ratio and resolution was all wrong, so i found out it had to be resized using Tmpeg or virtual dub first, the problem is i have no idea how to do this and does it take long, would the resize time plus the encoding in CCE take longer than just doing it all in TMpeg
thanks to anyone who replies
To answer your question... No, it won't take longer. CCE is FAST.
What I'd suggest is that you read up on frameserving from VDub to CCE. It's pretty easy to do, provided you're using CCE 2.50.
For all of your resizing needs in VDub, check out this excellent smart resizer. What works best for me is setting it to fit a picture size of 448x448, letterboxing it out to 480x480, and setting the aspect ration to 3/4 (NOT 4/3---trust me on this, something's a little off with the filter, perhaps).
In short, what you want to do is frameserve your video to CCE. Read up on this---it's fast, easy and saves a LOT of HD space. -
thanks a lot for replying i'll give it a try i've just downloaded the resizer, but im using CCE 2.62 is that a problem
Avi resizing or creating quick dvd using avidemux
By striker9 in forum Video ConversionReplies: 13Last Post: 2nd Nov 2010, 11:01 -
DVD to AVI resizing problem
By okman in forum DVD RippingReplies: 10Last Post: 2nd Jan 2010, 00:46 -
PAL to DVD Converting using CCE: Lanczos not resizing video!
By dianita in forum Video ConversionReplies: 5Last Post: 12th Dec 2009, 01:12 -
Convert 16:9 AVI to MP4 and resizing for mobile phone (?)
By wldworld in forum Video ConversionReplies: 2Last Post: 6th Jul 2008, 23:48 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 14:45
