I just can't fiqure it out. I have read through the forum and have not found anything that matches my problem. I had the older version of TmpgEnc 2.53 working on my comp, but when I installed 2.54a and try to load an avi or mpg I get an Error Signature and the program wants to close down. Then windows wants to creat an error report with something to do with this file (C:\DOCUME~1\Nos\LOCALS~1\Temp\WER39.tmp.dir00\app compat.txt). I have even tried to got back to the old version of TmpgEnc, and even reinstalled the OS, and I still get the same error, WTF is going with this damn thing. Help!!!!!!!!!!!!!![]()
Thanks,
Zorin
P.S. Sefy if u read this, that's is pretty jacked that those bastards took your help files and where selling them, you should sue their asses!!!!!!!!!
I'm all for this site and helping others as they have helped me.
Sounds like you are using Windows XP and run into some compatibility problem, have you tried going back to the older TMPGEnc to see if that one still works ?
P.S: Thank you!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I just went back to 2.53 and it did the same thing, any ideas, should i get a older, older version and try that?
The reason I suggested about a compatibility file is this: appcompat.txt
that sounds alot like Application Compatibility, which means there might be some compatibility problem in your system.
Have you ran and updated your XP using the Windows Update ?Email me for faster replies!
Best Regards,
Sefy Levy,
Sorry it took so long to get back to you, yes I have all the updates. Any other ideas?
This might be a longshot, but try deleting your entire TMPGEnc folder, and re-download TMPGEnc and see if it works again.
Best Regards,
Sefy Levy,
Serch fore "mplam6.dll" and rename it to mplam6.dll_ or somthing a like.
It worked fore me, the credit goes to a mOrg over at TMPGEnc's BBS http://www.tmpgenc.net/cgi-bin/ebbs/board.cgi?board=tmpgenc#topic8036ChRaN :-) -
You know the funny thing is that I was just looking at that post on that BBS before you posted this msg. I thought it have something to do with a Ulead program, I tried it and it works now, thanks for all your help Sefy and ChRaN, it's much appreciated.
Peace,
Zorin
What to keep in mind so that the dvd will play on all players?
By Srivas in forum Authoring (DVD)Replies: 8Last Post: 19th Dec 2011, 05:20 -
Hey, if you don't mind me asking, how do you upload more than 10 min in YT?
By Vlenbo in forum Video Streaming DownloadingReplies: 8Last Post: 25th Dec 2008, 16:21 -
I think I made my mind up about what Camera im Getting... check it out
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 30th Dec 2007, 23:37 -
Intresting project on my mind!
By fLYtRap in forum ComputerReplies: 6Last Post: 3rd Jun 2007, 08:30 -
Authoring a DVD - trying to put procedures straight in my mind.
By JaredKnight in forum Authoring (DVD)Replies: 1Last Post: 19th May 2007, 06:29
