Some movies I have downloaded have a slight background hiss all the way through, whats the best software to filter out this noise.
Craig
Demux the audio and video, then export the audio to a .wav. Open up Sound Forge, Cool Edit Pro, or your favorite audio editing program (Ray Gun is *excellent* for this type of thing), and run a noise-removal filter on it.
Save and remux. -
i used vdub exported the audio to a wav file then i used cool edit took a spot out of the wav file where i knew for a fact there was no usable audio like a black screen where the show is dead for a second then used it to create a noise profile to extract the his once that was done for best ruesults i repeated it making a second noise profile from the new audio then i used the second noise profile on the audio then with using both profiles i made an outstanding audio track then i just reintegrated it into my avi using vdub and resynced it and it was wonderful
Bob12345
atr 35s hiss sound
By Philip M in forum AudioReplies: 3Last Post: 7th Apr 2012, 04:21 -
Mic hiss problem ???
By 3thman in forum AudioReplies: 2Last Post: 26th May 2010, 11:24 -
Audio hiss removal in VirtualDub
By BobAchgill in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2009, 08:57 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jul 2007, 23:03
