anyone can learn me how can i put subtitles in vcds?
thank you for your attention
Slash
Just burn them into video. For example open movie with VirtualDub, use Subtitler filter by Avery Lee and open SSA subtitles. Then server it into MPEG encoder (TMPGEnc for example).
You can create SSA subtitles with my prog
Try my new version of subtitle Tool. Now it can play movies and edit subtitles realtime
http://www.tomzavodny.cz/program/subtool/
Tomas Zavodny -
Also my bitrate calculator could help you
http://www.tomzavodny.cz/program/bitcalc/ -
but i want to copy a VCD with subtitles to acess them in the DVD Player PIONEER DV-343
VCD only supports permanent subtitles. You can do a SVCD with switchable subtitles. Does your player do SVCDs? Does the Player do SVCD subtitles (there are a couple of flavors - my Philips 711 will do SVCD but not SVCD subs)?
Panasonic DMR-ES45VS, keep those discs a burnin' -
i think that my dvd player dont suports SVCD subtitles....
how can i put a subtitle in VCD pernamently?
thanks -
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 17:48 -
How to put subtitles in a m2ts file ?
By sn0wer in forum MacReplies: 4Last Post: 18th Mar 2010, 10:52 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
How do I get subtitles from a DVD to put into an XVid?
By Emanef in forum SubtitleReplies: 7Last Post: 23rd Jul 2008, 12:45 -
How to put subtitles to a mkv file
By donpato in forum SubtitleReplies: 2Last Post: 6th Apr 2008, 16:17
