using showshifter and capping in mjpeg, i tried to cap at 352X576 for reduction to 352X288 for vcd. all seemed well, until i looked at the video closely and realised it had only captured one field and repeated it! fair enough, i was only going to end up with one field anyway, but i can't seperate the 288 pixels i want from the 288 i don't because of the way the are arranged. they are in a 1,2,1,2,3,4,3,4 pattern. is there a filter for vdub or TMPGenc which will delete every other two lines for me, as it's really beggining to annoy me!
Results 1 to 1 of 1
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 23:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19
